PWM support? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: PWM support? (/showthread.php?tid=6749) Pages:
1
2
PWM support? - luis15pt - 09-19-2024 I have a KC868-A16 would it be possible to control a standard computer fan 12v that has PWM ? i know there are some GPIO ports, im assuming i have to configure one of these as PWM, how do i find out which ones they represent on the actual board? The next question is how do i monitor the RPM form the fan and where do i connect and configure it ? RE: PWM support? - admin - 09-19-2024 gpio32,gpio33,gpio14 support PWM output, but i have not tested, you can try to use it. RE: PWM support? - luis15pt - 09-20-2024 (09-19-2024, 11:16 PM)admin Wrote: gpio32,gpio33,gpio14 support PWM output, but i have not tested, you can try to use it. do you have a schematic for which outputs those are on the pcb? RE: PWM support? - admin - 09-20-2024 See this YELLOW region. RE: PWM support? - luis15pt - 09-20-2024 (09-20-2024, 11:50 AM)admin Wrote: Sorry if my message wasnt clear, how do i know which gpio32,gpio33,gpio14 connectors are? So i was looking for something like HT1 is gpio14, HT2 is gpio32 and HT3 is gpio33 ? pio33,gpio14 RE: PWM support? - admin - 09-20-2024 HT1:GPIO32 HT2:GPIO33 HT3:GPIO14 here is schematic of KC868-A16: https://www.kincony.com/download/KC868-A16-schematic.pdf RE: PWM support? - luis15pt - 09-20-2024 I kind of got it to work, so i can turn on the fan using this config: But the issue is the fan will only turn on at 100% speed at around halfway of the slider, and i can not control the speed, is there something else i need to do? As currently i can only have it at 0% or 100% speed. Ive tried PWM 1 to 5 only 1 seems to work. Also in regards to the RPM counter, i dont think the counter is working as its an increasing counter, so i might have to use something else ? I tried counter 2 to 5 same issue. Is there a way to have a RPM counter? RE: PWM support? - admin - 09-21-2024 Sorry, i am not used PWM in Tasmota. i suggest you post your questions to Tasmota forum. RE: PWM support? - luis15pt - 09-22-2024 What if i used stock firmware will that work ? or ESPhome? RE: PWM support? - admin - 09-22-2024 KCS not support PWM output. you can try to use by ESPHome. |
