M30 - Jumpers for CT inputs (voltage/mA) - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-M16 / M1 / MB / M30 (https://www.kincony.com/forum/forumdisplay.php?fid=50) +--- Thread: M30 - Jumpers for CT inputs (voltage/mA) (/showthread.php?tid=6829) |
M30 - Jumpers for CT inputs (voltage/mA) - raphaelcno - 10-02-2024 Hello ![]() I'm reading the description of the M30 board (https://www.kincony.com/esp32-energy-monitor-board.html). I see that it's possible to use CT clamps with voltage or mA signal. Can you tell me if the CT inputs on the M30 board are equipped with jumpers in order to choose between voltage and mA signal? Thank you in advance for your help ![]() Raphaël RE: M30 - Jumpers for CT inputs (voltage/mA) - admin - 10-03-2024 the jumper set for "mA" or "voltage" CT sensor. some CT sensor inside have connected resistors in parallel, so this is "voltage" type. RE: M30 - Jumpers for CT inputs (voltage/mA) - raphaelcno - 10-04-2024 Thank you for your answer ![]() Can you show on this picture where the jumpers are located? ![]() RE: M30 - Jumpers for CT inputs (voltage/mA) - admin - 10-05-2024 M30 not have the jumper, default use by "current" CT sensor. But you can also use "voltage" CT sensor, just "current" CT sensor will have a better data accuracy. M16 and M16v2 board have jumper for setting. RE: M30 - Jumpers for CT inputs (voltage/mA) - raphaelcno - 10-05-2024 Thank you for the clarification ![]() RE: M30 - Jumpers for CT inputs (voltage/mA) - JULIO - 11-25-2024 Greetings. I have successfully programmed my M16v2 board and it is reporting to ESPHOME, but the amp measurement graphs have a pattern that every 15 minutes the measurement drops to zero. I made some adjustments with lamda and it no longer drops to zero but the measurements continue to drop a considerable amount. Attached is the image of the measurements. RE: M30 - Jumpers for CT inputs (voltage/mA) - admin - 11-26-2024 already repied on your another thread. |
