server mini cm4 no don't boot - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module (https://www.kincony.com/forum/forumdisplay.php?fid=53) +--- Thread: server mini cm4 no don't boot (/showthread.php?tid=6877) |
server mini cm4 no don't boot - Krishi00 - 10-16-2024 Hi there, New server mini, new RASPBERRY-PI CM4108032 Raspberry Pi 8GB Compute Module 4 with WiFi, 32GB eMMC, new 24v ps, when I power it up it does not even connect to my switch... RE: server mini cm4 no don't boot - admin - 10-16-2024 a RE: server mini cm4 no don't boot - admin - 10-16-2024 do you have installed software for your CM4? if new controller, there is no firmware. Do you want to install home assistant or Node-red software? RE: server mini cm4 no don't boot - Krishi00 - 10-16-2024 I folowed your youtube instruction, installed home assistant, tried 3 different sd card... RE: server mini cm4 no don't boot - admin - 10-16-2024 you are using CM4 with eMMC version, so can't use SD card, only can use eMMC. if you use CM4 lite version, you can use SD card. |
