How to control RGBW 5pin led strip with A16 controller - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: How to control RGBW 5pin led strip with A16 controller (/showthread.php?tid=6892) Pages:
1
2
How to control RGBW 5pin led strip with A16 controller - Karnek - 10-21-2024 Hi! Can someone guide me how can I controll 5pin RGBW SMD 5050 led strip ( not addressable LEDs, total of ~25meters long, 5pcs x 5meters, 12v ) using A16 board & Home assistant ideally? RE: How to control RGBW 5pin led strip with A16 controller - admin - 10-21-2024 KC868-A16 not support this LED. you need to use KC868-D16 or KC868-AP dimmer controller. RE: How to control RGBW 5pin led strip with A16 controller - Karnek - 10-22-2024 (10-21-2024, 11:41 AM)admin Wrote: KC868-A16 not support this LED. you need to use KC868-D16 or KC868-AP dimmer controller. So if it is possible with KC868-D16 , then probably also possible with KC868-D8. If yes can show me how to do it please? I believe it is similar to this tutorial https://youtu.be/vZgvFhYxPt0?si=v2nAbk_i3DVb2Jwv I just want to have color wheel led control preferably in Home assistant. Thanks in advance! RE: How to control RGBW 5pin led strip with A16 controller - admin - 10-22-2024 yes, the video tour use by WS2812B RGB LED strip, it's easy. if you can replace with this new led strip, your KC868-A16 board can work with it. RE: How to control RGBW 5pin led strip with A16 controller - Karnek - 10-24-2024 (10-22-2024, 02:31 PM)admin Wrote: yes, the video tour use by WS2812B RGB LED strip, it's easy. if you can replace with this new led strip, your KC868-A16 board can work with it. Unfortunately I cannot replace my led strip, please suggest how to control this RGBW 5pin led strip with KC868-D8 as I already have these items bought and prefer to use these controllers ( D8 or A16). RE: How to control RGBW 5pin led strip with A16 controller - admin - 10-24-2024 KC868-D8 not support colorful LED strip. only use for monocolor LED strip. RE: How to control RGBW 5pin led strip with A16 controller - Karnek - 10-25-2024 Thank you for the answer! Is there any other cost effective, simple RGBW controller for Home assistant solution? As KC868-D16 costs 750Eur. https://www.aliexpress.com/item/1005005871145169.html?spm=a2g0o.productlist.main.1.57e21GTG1GTGiK&algo_pvid=14bc4cc4-432a-412b-a951-33fdce6b6762&algo_exp_id=14bc4cc4-432a-412b-a951-33fdce6b6762-0&pdp_npi=4%40dis%21EUR%21744.69%21744.69%21%21%215611.83%215611.83%21%40211b876e17298276532052860e9af7%2112000034647252834%21sea%21LT%21120786708%21X&curPageLogUid=NOPIbaNXDpsC&utparam-url=scene%3Asearch%7Cquery_from%3A RE: How to control RGBW 5pin led strip with A16 controller - admin - 10-25-2024 sorry, now no others. RE: How to control RGBW 5pin led strip with A16 controller - MariusM - 12-12-2024 How many RGBW 24V led strips can be controled with D16? RE: How to control RGBW 5pin led strip with A16 controller - admin - 12-13-2024 D16 is 16 channel version. KC868-D16 is DC 0-10v output board. if you want connect to 24v led strip, you need to add DRIVER. KC868-AP also is 16 channel version. KC868-AP have driver on PCB, you can connect to your 24V led strip directly. |
