Server16 raspberry pi - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module (https://www.kincony.com/forum/forumdisplay.php?fid=53) +--- Thread: Server16 raspberry pi (/showthread.php?tid=6894) |
Server16 raspberry pi - Saif Kitany - 10-21-2024 Hello kincony technical team support , I Have H32b controller, my question is like this: If I purchase server16 raspberry pi iot getway, then can i by node red to control h32b with a diagram that stand on my requirements? For example: My h32b is to control electrical windows in my home. So i want for example to open: 1. Window number 1at 5% 2. Window number 2 at 10% 3window number 3 at 100% . . . Etc… RE: Server16 raspberry pi - admin - 10-22-2024 1. you can integrate H32B to Server16 Node red by MQTT. 2. if you want window work by percent, you can use delay time for OPEN window, just calculate how many times with 5%,10%,100%. RE: Server16 raspberry pi - Saif Kitany - 10-22-2024 Great. Another question: I also have more 4 H32b, one for garden lights, one for inside lights ground floor, and one for 1st floor lights, and one for electrical water taps Can i integrate all of them with one server 16 node red by mqtt? RE: Server16 raspberry pi - admin - 10-22-2024 sure, just all H32B connect to router by ethernet, work in same local network. RE: Server16 raspberry pi - Saif Kitany - 10-22-2024 Great, thank you |
