MQTT PREFIX TOPIC could be changed in the kincony firmware webpage. - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Suggestions and feedback on KinCony's products (https://www.kincony.com/forum/forumdisplay.php?fid=39) +--- Thread: MQTT PREFIX TOPIC could be changed in the kincony firmware webpage. (/showthread.php?tid=6919) |
MQTT PREFIX TOPIC could be changed in the kincony firmware webpage. - Aladin - 10-25-2024 It's possible to permit MQTT PREFIX TOPIC to be changed in the kincony firmware webpage like in TASMOTA? SOME_CUSTOM_PREFIX/KC868_A16/B8D61B4AA69C/STATE or SOME_CUSTOM_PREFIX/XXXXX/XXXXX/STATEĀ Instead of : KC868_A16/B8D61A5AA69C/STATE You could keep the default PREFIX & permit to set the entire CUSTOM PREFIX. We also need to choose UPPERCASE or LOWERCASE format for the MQTT TOPIC. Thanks! RE: MQTT PREFIX TOPIC could be changed in the kincony firmware webpage. - admin - 10-25-2024 if you use KCS firmware can't be changed. If you want modfiy your own mqtt topic, suggest you use by ESPHome. |
