temperature/humidity modbus module - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Suggestions and feedback on KinCony's products (https://www.kincony.com/forum/forumdisplay.php?fid=39) +--- Thread: temperature/humidity modbus module (/showthread.php?tid=6966) |
temperature/humidity modbus module - mod5 - 11-02-2024 i would like to suggest a module like https://shop.kincony.com/products/rs485-temperature-and-humidity-sensor-modbus-rtu-use-by-sht30 It should be modbus, becouse 1wire couses problems for longer distances For european clients, we use 60mm round flush-mounted box and that product cant fit there. Mabye you can just did some KC868-HAv2 additional functionality? RE: temperature/humidity modbus module - admin - 11-02-2024 Do you means make a tiny RS485 SHT30 sensor? similar as HAv2 pcb size? or add the SHT30 sensor on the HAv2 PCB? RE: temperature/humidity modbus module - mod5 - 11-02-2024 (11-02-2024, 06:55 AM)admin Wrote: Do you means make a tiny RS485 SHT30 sensor? similar as HAv2 pcb size? or add the SHT30 sensor on the HAv2 PCB? Personaly i need tiny RS485 SHT30. I belive both product will be great 1. RS485 SHT30 sensor? similar as HAv2 pcb size, wide voltage range 12-24VDC 2. HAv2 with SHT30 sensor RE: temperature/humidity modbus module - admin - 11-02-2024 OK, save your suggestion. Maybe can design item-2 firstly. RS485 tiny SHT30 sensor. |
