KinCony SIM7600E-L1C 4G breakout LTE core module released - Printable Version
+--- Thread: KinCony SIM7600E-L1C 4G breakout LTE core module released (/showthread.php?tid=7131)
KinCony SIM7600E-L1C 4G breakout LTE core module released - admin - 11-28-2024
The SIM7600E-L1C is a versatile and cost-effective 4G LTE module that integrates multiple communication functionalities, making it suitable for a wide range of IoT and M2M applications. Developed by KinCony, this module provides robust connectivity and high-speed data transmission capabilities, ensuring seamless integration into IoT ecosystems.
[Image: sim7600-1_pix400.jpg][Image: sim7600-2_pix400.jpg]
[Image: sim7600-key-parts.png]
USB-C: connect with SIM7600E's USB port , debug by AT command
pin-S (SLEEP): set module to SLEEP mode
pin-G (GROUND): GND
pin-V (VCC): power supply DC 5-10V
pin-K (KEY): power on/off module
pin-T (TXD): send data
pin-R (RXD): receive data
pin-G (GROUND): GND
pin-RST: SIM7600 chip RESET pin
power chip: AZ1084CD
IPEX2: 4G antenna
IPEX4: GPS antenna
SIM card: Drawer SIM card holder (NANO)
TP1: DC4V power test point
SIM7600 network LED indicator: if blink means network registration successful
1: LED always ON: Searching network/call connect
2: LED 200ms ON, 200ms OFF: Data transmit
3: LED 800ms ON, 800ms OFF: Registered network
4: LED OFF: power off/Sleep
FPC1(16 pins) extender pins define:
[Image: sim7600-fpc.png]
[Image: sim7600-pcb.png]
