Replacing KCS868-E8 relays with 24V - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: Replacing KCS868-E8 relays with 24V (/showthread.php?tid=7148) |
Replacing KCS868-E8 relays with 24V - Revinor - 11-29-2024 I'm using 24V output from KCS868-B16M for controlling few devices. At same time, I would like to use some of these outputs to drive 230VAC. Can I just replace all relays on KCS868-E8 with G2R-1A-E-24VDC, connect 24V supply and 24V outputs from KCS868-B16M there and everything will work? Or are there some parts there which won't work with 24V even if all relays are replaced? RE: Replacing KCS868-E8 relays with 24V - admin - 11-29-2024 sure, just replace relay with 24v version is ok. You are right. |
