Error when flashing A32 Pro - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Error when flashing A32 Pro (/showthread.php?tid=7151) |
Error when flashing A32 Pro - drazvan2003 - 11-29-2024 im getting this error when im trying to flash my a32pro as you can see in the picture attached that my config, i hit run, it stays for ever in loading. When i stop this i get [2024-11-29 20:56:35,958][ESP8266Loader_spi[1]][espDownloader.py][line:422][ERROR]: Chip sync error [2024-11-29 20:56:35,958][ESP8266Loader_spi[1]][espDownloader.py][line:582][ERROR]: ESP32S3 Chip sync error esp_sync_blocking. RE: Error when flashing A32 Pro - admin - 11-29-2024 do you using A32 Pro controller, NOT KC868-A32, right? take a screen photo, what chip type you have chose. RE: Error when flashing A32 Pro - drazvan2003 - 11-30-2024 Its says ESP32-S3-WROOM RE: Error when flashing A32 Pro - admin - 11-30-2024 my means: the ESP download tool first step need you chose chip type. do you have chose ESP32-S3 and USB ?
RE: Error when flashing A32 Pro - drazvan2003 - 11-30-2024 Yes i have done exactly that and it doesnt work....it remains in non stop loading and ingrt the message i posted earlier. Chip blocked RE: Error when flashing A32 Pro - drazvan2003 - 11-30-2024 after switching 6 usb cables i was able to flash and add it in home assistant RE: Error when flashing A32 Pro - admin - 11-30-2024 ok, need use high quality USB-C cable. |
