Door Access Control System - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Door Access Control System (/showthread.php?tid=7158) |
Door Access Control System - PeterOo - 12-02-2024 Hi, As per the link below, https://www.kincony.com/remote-access-controlling-solution.html I found out that KC868 relay controllers can be configured to be used as door access control system. But, in that solution, I only found out ( or may be I missed out ) magnetic door locks and exit buttons used with controller. I wonder if there are any possible solutions to use proximity card reader (with Weigand interface, later, convert to RS485 from Weigand) with the relay controllers. Could you please suggest me a way to integrate door access control system to KINCONY relay controller? Or, if you have any recommended card readers of any kinds or KINCONY's own card reader models, please enlighten me. I would like to integrate door access control system in my smart home project. Thanks in advance. RE: Door Access Control System - admin - 12-02-2024 you can check with this video tour: https://youtu.be/v-Vs4NbJy5k RE: Door Access Control System - PeterOo - 12-08-2024 Thank you for your support, I have watched the video. I've found that I can find a solution for door access system with that Wiegand keypad card reader supported from ESPhome. RE: Door Access Control System - admin - 12-08-2024 ok |
