Board KC868_A16 FW 2.2.7 no value sensor MQTT - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Board KC868_A16 FW 2.2.7 no value sensor MQTT (/showthread.php?tid=7189) |
Board KC868_A16 FW 2.2.7 no value sensor MQTT - kerdalle - 12-07-2024 Hello, I updated my card with the latest firmware 2.2.7 and I have a problem with MQTT and sensor 1,2,3. I installed a DS18B20 sensor on sensor 3 It is displayed well and gives the right temperature on the Monitor web page. However I have the zero value with mqtt: topic KC868_A16/ECC9FFB5F36C/STATE value: {"input1":{"value":false},"input2":{"value":false},"input3":{"value":false},"input4":{"value":false},"input5":{"value":false},"input6":{"value":false},"input7":{"value":false},"input8":{"value":false},"input9":{"value":false},"input10":{"value":false},"input11":{"value":false},"input12":{"value":false},"input13":{"value":false},"input14":{"value":false},"input15":{"value":false},"input16":{"value":false},"output1":{"value":false},"output2":{"value":false},"output3":{"value":false},"output4":{"value":false},"output5":{"value":false},"output6":{"value":false},"output7":{"value":false},"output8":{"value":false},"output9":{"value":false},"output10":{"value":false},"output11":{"value":false},"output12":{"value":false},"output13":{"value":false},"output14":{"value":false},"output15":{"value":false},"output16":{"value":false},"adc1":{"value":0},"adc2":{"value":0},"adc3":{"value":0},"adc4":{"value":0},"sensor1":{"temperature":0.0,"humity":0.0},"sensor2":{"temperature":0.0,"humity":0.0},"sensor3":{"temperature":0.0,"humity":0.0}} topic KC868_A16/ECC9FFB5F36C/STATE [sensor3] value {"temperature":0,"humity":0} topic KC868_A16/ECC9FFB5F36C/STATE [sensor3][temperature] value 0 KC868 monitor web page sensor chanel 3 show good température 21.2 witch varie according room température. I think read all post and nothing found abour this problem. With the software MQTT explorer it's idem Inputs, outputs state and order works fine with mqtt. Where I am wrong? Edit: I have also for test connect ADC chanel 4 on board 3V . Web page MONITOR board display value 4095 but in MQTT topic stil 0: "adc1": { "value": 0 }, "adc2": { "value": 0 }, "adc3": { "value": 0 }, "adc4": { "value": 0 }, RE: Board KC868_A16 FW 2.2.7 no value sensor MQTT - admin - 12-07-2024 Click the gear button in the upper right corner to set the minimum difference reported by MQTT RE: Board KC868_A16 FW 2.2.7 no value sensor MQTT - kerdalle - 12-08-2024 (12-07-2024, 11:48 PM)admin Wrote: Click the gear button in the upper right corner to set the minimum difference reported by MQTTI am very confused to have wasted your time, I am a real beginner with the philosophy of Kincony firmware, I suspected that it was a mistake on my part, the firmware could not be the cause. Thank you again a thousand times for your unfailing assistance. RE: Board KC868_A16 FW 2.2.7 no value sensor MQTT - kerdalle - 12-08-2024 (12-08-2024, 01:53 PM)kerdalle Wrote:(12-07-2024, 11:48 PM)admin Wrote: Click the gear button in the upper right corner to set the minimum difference reported by MQTTI am very confused to have wasted your time, I am a real beginner with the philosophy of Kincony firmware, I suspected that it was a mistake on my part, the firmware could not be the cause. Thank you again a thousand times for your unfailing assistance. I'm exaggerating!!: just a question about the sensor setting. Can the temperature threshold be decimal (for example 0.1) or just an integer? RE: Board KC868_A16 FW 2.2.7 no value sensor MQTT - admin - 12-09-2024 it can be 0.1 |
