A6 Tasmota.bin for quick start - Printable Version
+--- Thread: A6 Tasmota.bin for quick start (/showthread.php?tid=7191)
A6 Tasmota.bin for quick start - korl - 12-07-2024
Hello everyone,
I would like to run Tasmota (newest version) on the A6 (and A16). I ran through the TasmoCompiler, downloaded and flashed provided firmwares by "admin", and used the tutorials with going through the settings (e.g. Setting PCF8574 manually),
I could  not get Tasmota running with all the Hardware in- and outputs (DI, DO, 0-10 V,...)
Could someone just provide the Tasmota bin-file for the A6 and the A16 (for ethernet)?
Best wishes,
korl
RE: A6 Tasmota.bin for quick start - admin - 12-07-2024
Do you tested with this firmware?
https://www.kincony.com/forum/showthread.php?tid=2405
RE: A6 Tasmota.bin for quick start - korl - 12-08-2024
Thank you for your quick reply!
When flashing this firmware( [Image: zip.png]   tasmota_KC868-A6-20221128.zip (Size: 997.56 KB / Downloads: 270)), this is the console output.
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
invalid header: 0x3f400c78
ets Jul 29 2019 12:21:46
I flashed with ESP-Flasher, and this is the start screen:
So, no inputs, outputs or analog channels shown.
After adding the template from https://templates.blakadder.com/kincony_KC868-A6.html  the start page looks the same.
I thought, when flashing the provided firmwware, it should run out-of-the-box. Are there any further instructions, I might have missed after flashing to get all input, outputs and analog values?
For me this is interesting for A6 and A16 without display and without LoRa.
Another Question, I tried to build for A6 via TasmoCompiler with these Settings:
Are these settings ok? (When choosing ESP8266, as in your tutorial here https://www.kincony.com/forum/showthread.php?tid=2369, it did not work after flashing)
Is there an actual tutorial about TasmoCompiler?
RE: A6 Tasmota.bin for quick start - admin - 12-08-2024
how to compile new tasmota firmware by simplest way: https://www.kincony.com/forum/showthread.php?tid=5432
