0-10v in analog input - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21) +--- Thread: 0-10v in analog input (/showthread.php?tid=7196) |
0-10v in analog input - GDN20 - 12-09-2024 please tell me, if I connect a voltage over 10v to the analog input 0-5v, will the port (pin) break? Do I understand correctly that at a voltage above 5v, the value will be 4095? RE: 0-10v in analog input - admin - 12-09-2024 if you input 10v will not broken board, but the input port design for MAX 5v for user. RE: 0-10v in analog input - GDN20 - 12-09-2024 (12-09-2024, 08:16 AM)admin Wrote: if you input 10v will not broken board, but the input port design for MAX 5v for user. that is, if 10v is connected for more than 24 hours, and then 3.3v is connected, will the readings be correct? RE: 0-10v in analog input - admin - 12-09-2024 you can test it. |
