AG8 + ESPHOME + SmartIR - Printable Version
+--- Forum: KC868-AG / AG Pro / AG8 (https://www.kincony.com/forum/forumdisplay.php?fid=30)
+--- Thread: AG8 + ESPHOME + SmartIR (/showthread.php?tid=7198)
AG8 + ESPHOME + SmartIR - tenabiker - 12-09-2024
I`m Trying to integrate AG8 with SmartIR project. It uses "remote" entity to transmit raw data from homeassistant directly to device.
https://github.com/smartHomeHub/SmartIR
I had sucess using broadlink rm4 pro transmiter, but AG8 entity do not appear at homeassistant remote entities:
I`m using following yaml file:
  friendly_name: ag8-teste
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
    sdkconfig_options:
      SOC_RMT_SUPPORT_RX_PINGPONG: "n"
wifi:
  ssid: !secret wifi_ssid
remote_receiver:
  pin: 48
  rmt_channel: 4
  dump: all
remote_transmitter:
  - id: ir1
    pin: 9
    carrier_duty_percent: 50%
    rmt_channel: 0
  - id: ir2
    pin: 10
  - id: ir3
    pin: 11
  - id: ir4
    pin: 12
  - platform: template
    turn_on_action:
      - remote_transmitter.transmit_panasonic:
          transmitter_id: ir1
          address: 0x4004
          command: 0x8140DFA2
    turn_on_action:
          transmitter_id: ir2
          address: 0x4004
          command: 0x8140DFA2
    turn_on_action:
          transmitter_id: ir3
          address: 0x4004
          command: 0x8140DFA2
    turn_on_action:
          transmitter_id: ir4
          address: 0x4004
          command: 0x8140DFA2
  - platform: uart
    uart_id: uart_485
  - platform: uart
    uart_id: uart_232
    data: "RS232-test"
uart:
  - id: uart_485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 18
    rx_pin: 8
  - id: uart_232
    baud_rate: 9600
    debug:
      direction: BOTH
      after:
        timeout: 10ms
      sequence:
        - lambda: UARTDebug::log_string(direction, bytes);
    tx_pin: 17
    rx_pin: 16
      number: 15
      mode:
        input: true
        pullup: true
      number: 38
      mode:
        input: true
        pullup: true
      number: 39
      mode:
        input: true
        pullup: true
      number: 40
      mode:
        input: true
        pullup: true
web_server:
  port: 80
Device work just fine with other functions:
Only remote.ag8-teste entity is not working.
Anyone has an idea what could be my mistake ?
I`m using updated version possible:
  • Core2024.12.1
  • Supervisor2024.11.4
  • Operating System14.0
  • Frontend20241127.6
  • ESPHome addon: 2024.11.3
I appreciate all kind of help.
RE: AG8 + ESPHOME + SmartIR - admin - 12-09-2024
Do you means , you can send IR signal by button in home assistant, but can't listed as a remote in home asssistant?
RE: AG8 + ESPHOME + SmartIR - tenabiker - 12-10-2024
(12-09-2024, 10:55 PM)admin Wrote: Do you means , you can send IR signal by button in home assistant, but can't listed as a remote in home asssistant?
Thats right ..... entity remote.ag8-teste doesn`t exist.
RE: AG8 + ESPHOME + SmartIR - admin - 12-10-2024
how go to home assistant remote entities webpage? can you upload some photos, whether get the webpage.
(12-10-2024, 11:20 AM)admin Wrote: how go to home assistant remote entities webpage? can you upload some photos, whether get the webpage.
Like this one ?
