no access to kcs - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: no access to kcs (/showthread.php?tid=7214) |
no access to kcs - philippe - 12-12-2024 Hi, I received a new A8 board, downloaded KCS with success, off/on the board. But I cant see the board on my net. Even with your tool udp scan. The board is on the same switch than my PC. Udp scan can see my two other kincony board. I tried both kcs V2, the V1..no luck. No problem with Tasmota, I have a wifi access to the board (but not via wire). I remember , installing them last year was not esay for me, spending too much time. I have 110 ish IP address on my Lan, many vendors, so far switches from shelly ,dingtian. I added kincony for the 1wire support. But man, am I stupid for having so much problem with the K boards boards or is my english broken? I hope so and that you will point me to the solution. Would be so easy for me, to have new board coming with kcs de facto. Also, I tried to integarte it on HA. I thought it would be easy like the videos show : just copy and paste! . No way, I am fighting with the yaml syntax . I know I should learn the yaml syntax. But you could simplify my job by posting yaml files not text ( or it is hidden on the website?) . Yes I am dumb with yaml. But for newbies like me, we would be more enclined to buy kincony stuff. Question: When kcs starts for the first time, is dhcp activated? on wired lan first , right? I posted my request by email, as you suggest when I contacted via ali. You reply that I should go to the forum. So please for new buyers, on ali , suggest to contact you on the forum. Thanks RE: no access to kcs - admin - 12-13-2024 1. You are downloading KCS v2.2.2, please download the newest firmware, here is download link: https://www.kincony.com/forum/showthread.php?tid=7046 2. when you use ESP-Download tool, the download address is error, you are using 0x10000, please change to 0x0 this is why your program can't run. 3. after you download firmware, re power on, then ethernet will work by DHCP mode. You can use KinCony scan device tool to find out the board's ip address. you will use web browser login by this ip address. RE: no access to kcs - philippe - 12-13-2024 Thanks, will try that.Cheers RE: no access to kcs - admin - 12-14-2024 work well now? RE: no access to kcs - philippe - 12-14-2024 (12-14-2024, 01:14 AM)admin Wrote: work well now?Yes , I got it working. As I want to migrate my home automation to ha, I am learning now how to make the board recognized by HA. So far its ok with using the wire, having the digital input/output recognized. Trying now to make the mqtt working. Tanks for your quick support. Philippe (whats your firstname?) RE: no access to kcs - admin - 12-15-2024 ok, good. i am xuwei. |
