KC868-A8 Switch - Printable Version
+--- Thread: KC868-A8 Switch (/showthread.php?tid=7215)
KC868-A8 Switch - glorifiedg - 12-12-2024
Hi!
I purchased some KC868-A8 to install in my new home and I'm now testing them.
I flashed one with ESPHome but the switches don't change relay state unless I program an automation in Home Assistant to do that (if input1 on/off change alternate relay state). Is it there anyway to configure this without HA? Should I use another firmware for this?
I also like to know if there any other device that can work with dimmable leds.
RE: KC868-A8 Switch - admin - 12-12-2024
1. you can download KCS v2 firmware , then config IFTTT let INPUT toggle OUTPUT. here is online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
2. if you want use dimmer LED, you can chose KC868-D16 dimmer controller or KC868-AP dimmer controller.
RE: KC868-A8 Switch - Verresen - 12-19-2024
Sorry to ask question here , but i have same problem.
I have my kc868 a8 board just by mail.
I installed kc868_a8_v1.0.10.
Then installed the local network with the ip 192.168.4.1.
Every thing ok,  even the KBOX smart app was working.
Local trigger relay.
Now i wanted to add metal frame momentary wall switch panel 6 gang .
But i cant find solution to connect the on how to connect the switch .
Then installed firmware kc868_a8_v2.2.8 . For the iftt option ?
But now i cant connect local to the ip 192.168.4.1??
I just want to mount the 6 gangs switch , and control 6 relays with it .
RE: KC868-A8 Switch - admin - 12-20-2024
KCS v2 have IFTTT function, v1 no IFTTT.
[Image: ifttt-drag.png]
