Using a different pull-up voltage for GPIO - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Using a different pull-up voltage for GPIO (/showthread.php?tid=7246) |
Using a different pull-up voltage for GPIO - xxteh - 12-20-2024 Hello, I am trying to use very long wires to connect multiple DS18B20 sensors to Kincony A16. I can successfully implement the system using Arduino UNO by providing 5V with a 1k pullup resistor and would like to replicate the same thing with Kincony. How can I achieve the same result with Kincony A16 as it only provides 3.3v pull up? RE: Using a different pull-up voltage for GPIO - admin - 12-20-2024 do you will write arduino code for KC868-A16? or do you want to use KCS firmware with your multi DS18B20 sensors. RE: Using a different pull-up voltage for GPIO - xxteh - 12-21-2024 (12-20-2024, 12:55 PM)admin Wrote: do you will write arduino code for KC868-A16? Would prefer to write arduino code for A16 RE: Using a different pull-up voltage for GPIO - admin - 12-22-2024 it's ok, we have tested before. here is demo details: https://www.kincony.com/forum/showthread.php?tid=2290 RE: Using a different pull-up voltage for GPIO - xxteh - 12-23-2024 (12-22-2024, 02:47 AM)admin Wrote: it's ok, we have tested before. As I am using very long wires, this wiring does not work for my project. I need to externally provide power(voltage) and a different value of pull-up resistor to make this work. Does the digital pins work like the Arduino's GPIO? RE: Using a different pull-up voltage for GPIO - admin - 12-23-2024 if you want to use for long distance, the best way is chose RS485 sensor. |
