Lora code - Printable Version
+--- Thread: Lora code (/showthread.php?tid=7267)
Lora code - EHB - 12-27-2024
Is there LoRa code for me to peruse while I wait for my new board (KC 868-A6 I think)
Thanks!
RE: Lora code - admin - 12-28-2024
https://www.kincony.com/forum/forumdisplay.php?fid=22
here are SX1278 LoRa module arduino demo code
RE: Lora code - EHB - 12-28-2024
Thanks. I have a LoRaWAN gateway running Chirpstack V4 locally.
I think I need more than just the LoRa library. Is it possible to install this library?
https://github.com/mcci-catena/arduino-lmic
From memory in Chirpstack the device needs a unique identification number and an activation code.
i am not sure, you can test it. there are many LoRaWAN arduino library on the internet.
RE: Lora code - EHB - 01-06-2025
Just received the item. The LoRA antenna just gets soldered onto the pin at the extreme inside away from the relays like in the photo I found?
RE: Lora code - admin - 01-06-2025
take a photo
RE: Lora code - EHB - 01-07-2025
Does that make sense? I was going to solder the antenna to the top left pin on the LoRa PCB.
RE: Lora code - admin - 01-07-2025
[Image: attachment.php?aid=2332]
Thanks. That is the pin I was going to solder it to but it’s good to have confirmation. If I solder it upright like that will it fit in the box? I was going to solder it in an angle but that looks nicer.
If I solder it upright like that will it fit in the box? sure, no problem, the plastic shell space is enough.
