Problem in output relay - Printable Version
+--- Forum: KC868-A16S (https://www.kincony.com/forum/forumdisplay.php?fid=47)
+--- Thread: Problem in output relay (/showthread.php?tid=7270)
Problem in output relay - Bergoglio - 12-27-2024
Good afternoon,
I flashed several times the KC868-A16S board with ESPHome firmware but the relay n. 8 remains always in on state (also the status led on the board) and it is impossible to control it.
This is the last firmware (still with the problem) :
  friendly_name: Centralina citofono
esp32:
  board: esp32dev
  framework:
    type: arduino
  encryption:
    key: "E3acLht11PoN5oLlgBJPgIO/+elvX80lTzGbQPfVnH8="
ota:
  - platform: esphome
    password: "0b4d665617eac63f109a0dd7b51a409e"
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
pcf8574:
    address: 0x24
    address: 0x25
    address: 0x22
    address: 0x23
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode:
        output: true
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
  - platform: restart
    name: EspHome Node Restart
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
Can You help me ?
RE: Problem in output relay - admin - 12-28-2024
open A16S BLACK metal box, there is white manual control button inside. make sure the number 9 button have not pressed, if pressed, just release it.
RE: Problem in output relay - Bergoglio - 12-28-2024
Ok, fine !
I opened the metal box and the number 8 button on white manual control was pressed, I released it and all start to work in the right way.
Thank You very much !
RE: Problem in output relay - admin - 12-29-2024
ok, good.
