coding support - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21) +--- Thread: coding support (/showthread.php?tid=7274) |
coding support - Salman - 12-27-2024 greetings, I would like to do the followings 3 digital input and one digital output the trouble that digital input 3 should be permissive low to activiate relay 1. then I would the software while the relay 1 is activiated, to monitor digital input 3. if it is remain high, keep relay 1 if it is switch to low , de activate relay 1 if ( digital input 1 == high and digital input 2 == high and digital input 3 == low ( this is will be permissive signal ) ) digital output 1 == high if ( digital input 1 = low and digital input 2== low ) digital output 1 == low if ( digital input 3 == low ) delay 1 minute digital output 1 = low RE: coding support - admin - 12-28-2024 you can download KCS firmware, set IFTTT. here is online guide of KCS v2: https://www.kincony.com/esp32-kcsv2-firmware.html |
