KC868-a6 Relay switches - Printable Version
+--- Thread: KC868-a6 Relay switches (/showthread.php?tid=7336)
KC868-a6 Relay switches - icemannz - 01-08-2025
Hi, I have a KC868-a6 board and it is up and running with ESPHome.
I can control all the relays via Home Assistant without issue.
What I would like to do is also have manual switches mounted on the box so I can switch a relay on or off.
I thought that grounding the DI-1 through 6 pins were for this but they don't appear to work that way.
Is there a way to connect up 6 small switches to the board to allow for manual switching if the relays ?
RE: KC868-a6 Relay switches - admin - 01-08-2025
sure, you can connect switch button with digital input ports. But you should config ESPHome yaml , let INPUT toggle OUTPUT. you can check with ESPHome guide.
RE: KC868-a6 Relay switches - icemannz - 01-09-2025
(01-08-2025, 05:01 AM)admin Wrote: sure, you can connect switch button with digital input ports. But you should config ESPHome yaml , let INPUT toggle OUTPUT. you can check with ESPHome guide.
I managed to track down the Yaml code required and now it works great,
Thanks for the pointer.
RE: KC868-a6 Relay switches - admin - 01-09-2025
ok, good.
