Advice for a board - Printable Version
+--- Thread: Advice for a board (/showthread.php?tid=7342)
Advice for a board - Bergoglio - 01-08-2025
Good morning,
I'm searching a simple ESP32 board with these connections :
- 1 LAN rj45 port
- 2 dry contacts for two different switches
- 2 GPIO pins to pilot one DFRobot DFPlayer Mini MP3 Player
- 1 GPIO pin to pilot a RGB led strip (probably a WS2812 chip)
Because I'm quite a noob in electronic, I'm not able to choose between Your products and I need Your help / advice.
Best regards
RE: Advice for a board - admin - 01-09-2025
you can check with KC868-A2: https://www.kincony.com/esp32-4g-relay.html
RE: Advice for a board - Bergoglio - 01-09-2025
Ok, I understand that I can wiring in this way :
- on DI 1 one of the two switch
- on DI 2 the second switch
- on GPIO 1 the led strip data cable
but where can I connect the two pins of DFRobot DFPlayer Mini MP3 Player (TX / RX) ?
if your Mini MP3 Player (TX / RX) is 3.3v level. KC868-A2 I2C bus SDA, SCL can be used. the WHITE color socket.
