KC868-A16S multiple DS18B20 possible ? - Printable Version
+--- Forum: KC868-A16S (https://www.kincony.com/forum/forumdisplay.php?fid=47)
+--- Thread: KC868-A16S multiple DS18B20 possible ? (/showthread.php?tid=7344)
KC868-A16S multiple DS18B20 possible ? - land88 - 01-09-2025
Hi,
I have connected on KC868-a16S a DS18B20 on 1-Wire input, it's ok with KCS.
Is it possible to put an other DS18B20 in parallel ? I have try, but not possible to see an other sensor temperature.
If not possible with an other DS18B20, is it possible with other sensor type ? by exemple thermistance NTC b3950-10K on Analogic ADC input ? (I think there is two positions analogic for voltage)
Thanks.
RE: KC868-A16S multiple DS18B20 possible ? - admin - 01-09-2025
KCS v2 not support one GPIO work with multi sensor.
support sensor type: DS18B20, DHT11, DHT22
if you want use analog input ports, you can use any 0-5v analog output signal sensor.
