Using KC868-G hub - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Using KC868-G hub (/showthread.php?tid=74) |
Using KC868-G hub - James Alabama - 12-14-2020 I have a question about how to use KC868-G - hub: KC868-COL gets digital input from motion sensors. I would like to setup scenes using motion sensor input and KC868 IFTTT commands to turn on/off smart lights (RF or wifi), alarm etc. Can this be setup between KC-COL and KC868-G? RE: Using KC868-G hub - admin - 12-15-2020 KC868-G is wifi version RF and IR smart controller. KC868-COL can't run control KC868-G, if you want to send RF signal to control RF device by IFTTT, you can use KC868-S, because KC868-S have RS485 port, it can connect with KC868-COL, running IFTTT automatic control function. |
