Industrial sensor compatibility (4-20ma - NTC) - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Industrial sensor compatibility (4-20ma - NTC) (/showthread.php?tid=7472) |
Industrial sensor compatibility (4-20ma - NTC) - Balteck - 01-25-2025 Hello, I discover this item recently. Before order one, I wish to now if it is possibile to connect an industrial sensor (Temperature and Humidity) that works in this way: 2-wires NTC 10K for the temperature 2-wires 4-20ma for the humidity I need that the board sends values to a MQTT broker with ethernet. any help? Thank you very much RE: Industrial sensor compatibility (4-20ma - NTC) - admin - 01-26-2025 i suggest you check with kincony A24 controller. it not support NTC 10K , but it support K-type thermocouple. here is details: https://www.kincony.com/esp32-k-type-thermocouple-24ch-relay-module.html |
