KC868-A16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: "KCS" firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40) +--- Thread: KC868-A16 (/showthread.php?tid=7476) |
KC868-A16 - juansa2 - 01-25-2025 can i extend IO A16 with two A16? RE: KC868-A16 - admin - 01-26-2025 what firmware you are using? KCS or ESPHome? RE: KC868-A16 - juansa2 - 01-26-2025 (01-26-2025, 12:29 AM)admin Wrote: what firmware you are using? KCS or ESPHome?KCS V2.2.10 RE: KC868-A16 - admin - 01-27-2025 i don't know what software you will use , home assistant? tuya app? or ? all KC868-A16 work independently, just connect with ethernet cable is ok. RE: KC868-A16 - juansa2 - 01-27-2025 (01-27-2025, 12:51 AM)admin Wrote: i don't know what software you will use , home assistant? tuya app? or ? Tuya app. RE: KC868-A16 - admin - 01-27-2025 ok, all KC868-A16 just connect to your router by wifi or ethernet. so that can use one tuya app for multi boards. you don't need connect wire with KC868-A16 for each other. |
