Pull up on A8 - Printable Version
+--- Thread: Pull up on A8 (/showthread.php?tid=7492)
Pages: 1 2
Pull up on A8 - heffneil - 01-27-2025
I am using ESPHome and I am seeing a lot of problems with the floating input.  Can someone tell me if I can specify pullup?  I tried with esphome normally and it doesn't like it so I am stuck?
RE: Pull up on A8 - admin - 01-27-2025
which port you are using? take a photo. because the 1-wire ports, it already have pull up resistance on PCB.
RE: Pull up on A8 - heffneil - 01-28-2025
I am using the ports directly to the right of the power input:
picture here:
https://imgur.com/a/FLl1CRC
RE: Pull up on A8 - admin - 01-28-2025
[Image: KC868-A8-1_03.jpg]
see this photo. S1, S2, S3, S4 ports all have pull up resistance on PCB.
(01-28-2025, 01:01 AM)admin Wrote: [Image: KC868-A8-1_03.jpg]
But I am using the inputs on the top left ground to input off the one chip
[color=oklab(0.89908 -0.00192907 -0.0048306)]  - platform: gpio
    name: "Water Closet Door Sensor"
      pcf8574: pcf8574_hub_in_1
      number: 1
      mode: INPUT
    filters:
      - delayed_on: 0.5s
[/color]
Do these have pull up resistors?  I am seeing significant bouncing?
digital input ports ONLY use for dry contact signal.
they are without pull up resistors, because of they not connect with ESP32's pin directly, there are PCF8574 chip's pin.
I am sorry I don't understand what you are saying. Are you saying I need pull up resistors?
      number: 1
      mode: INPUT
    filters:
      - delayed_on: 0.5s
[/color]
these port can't use pull up resistor. they are not connect with ESP32 pin directly. i suggest you test with S1,S2,S3 or S4 port.
      number: 1
      mode: INPUT
    filters:
      - delayed_on: 0.5s
[/color]
RE: Pull up on A8 - heffneil - 01-29-2025
what are these ports typically used for? This is closed contact testing and shouldnt flap.
