Ethernet and Bluetooth both enabled in ESP Home at the same time - Printable Version
+--- Thread: Ethernet and Bluetooth both enabled in ESP Home at the same time (/showthread.php?tid=7567)
Ethernet and Bluetooth both enabled in ESP Home at the same time - kennedyed - 02-06-2025
Hi There,
I have recently started using the KC868-A16 board and it is an excellent board.
I have loaded it with ESP Home and it is working well.
It is connected to my network via Ethernet for reliability and I also wish to enable Bluetooth on the board so as to use it as a gateway for BLE sensors in ESP Home and Home Assistant.
Do you know is it possible to use Bluetooth and Ethernet in the same ESP Home configuration on the KC868-A16 board?
I know W-Fi and Bluetooth  can work at the same time but I want use Ethernet as Wi-Fi coverage is poor at the location.
If I can use Ethernet and Bluetooth would you have an example ESP Home configuration for Bluetooth?
Thanks,
Ed.
RE: Ethernet and Bluetooth both enabled in ESP Home at the same time - admin - 02-07-2025
i am not used bluetooth in ESPHome, maybe you can check at here: https://esphome.io/components/bluetooth_proxy.html
