A24 + power socket - Printable Version
+--- Forum: KinCony A24 (https://www.kincony.com/forum/forumdisplay.php?fid=56)
+--- Thread: A24 + power socket (/showthread.php?tid=7580)
A24 + power socket - skench - 02-08-2025
Good day, I drew the diagram using the site https://app.diagrams.net/
Dear friend, please tell me if I understand the diagram for connecting the power socket pcorrectly?
Is it possible to do without a contactor and use only a machine?
RE: A24 + power socket - admin - 02-08-2025
if you are using AC contactor, the diagram is right.
RE: A24 + power socket - skench - 02-08-2025
Last question.
To work with the socket, should we use the standard example on the page https://www.kincony.com/forum/showthread.php?tid=3922 or do we need to make changes?
The socket should always be in the "on" status, how can we add this feature to the code?
not need to change yaml, directly to use.
if you want relay always ON, just turn on the relay, never turn it off.
