RS485 Modbus working ESPHome configuration - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: RS485 Modbus working ESPHome configuration (/showthread.php?tid=7585) |
RS485 Modbus working ESPHome configuration - darsh - 02-08-2025 Hello everyone! I wanted to share my ESPHome configuration for interfacing with a solar charge controller (Epever LS1024B) using RS485. This setup allows to read the PV voltage from the controller's register. Below is the working configuration that I used, which may help others facing similar challenges. Code: # UART configuration I hope this helps others in the community. RE: RS485 Modbus working ESPHome configuration - admin - 02-08-2025 thanks share your result. |
