Time issue on KC868-A4S - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: "KCS" firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40) +--- Thread: Time issue on KC868-A4S (/showthread.php?tid=7591) |
Time issue on KC868-A4S - PeterOo - 02-09-2025 Hi, Board: KC868-A4S Version installed: v2.2.10 Network: AP mode I have same IFTTT issue with time control just like other guys. I set the time zone the same as in my laptop. I set the time condition in the IF box I set the relay output in the THEN box I enabled the IFTTT function But, the relay output still not working help me what to do. RE: Time issue on KC868-A4S - admin - 02-09-2025 if you set the time zone = UTC+8 if Chinese time, not your local time. if your time is 11:56AM, you can set 11:57AM in IFTTT. |
