GI - ESPHOME - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=66) +--- Forum: G1 (https://www.kincony.com/forum/forumdisplay.php?fid=67) +--- Thread: GI - ESPHOME (/showthread.php?tid=7633) |
GI - ESPHOME - Trikinov - 02-17-2025 Will G1 be suported under ESPHOME ? Do you have information on how to send SMS from Home Assistant over Ethernet ? RE: GI - ESPHOME - admin - 02-17-2025 esphome not support 4G module directly. But you can config by serial port to send AT command for SMS can voice call. we already upload ESPHome yaml demo. see here: https://www.kincony.com/forum/forumdisplay.php?fid=54 another news, we will design KCS v3 firmware for G1 controller, so that can use SMS can CALL easily. RE: GI - ESPHOME - Trikinov - 02-18-2025 The serial option will not work for me, I need Ethernet What I realy want is a frmware that give me a mqtt2sms gatway. Where I can send a JSON object wiith number and text to one subject to send. And that all incoming SMS is published on another subject. That will be very vesatile and usefull RE: GI - ESPHOME - admin - 02-18-2025 What kind of application scenario is this? i think it's a good idea. maybe we can add this function. RE: GI - ESPHOME - Trikinov - 02-19-2025 This will be usefull in a number of senarioes. MQTT is widely adapted. I would use this from Home Assistant and Node-red. But it could also be used from other software that support MQTT. This will give a easy, and simple to integrate solution. RE: GI - ESPHOME - admin - 02-19-2025 ok, will add this feature to G1 KCS v3 firmware. now under desiging. |
