KC868-HA-V21 serial port selector drop box freezing - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-HA /HA v2 (https://www.kincony.com/forum/forumdisplay.php?fid=55) +--- Thread: KC868-HA-V21 serial port selector drop box freezing (/showthread.php?tid=7710) |
KC868-HA-V21 serial port selector drop box freezing - PeterOo - 02-23-2025 Hi admin, when I click the serial port drop box, the app doesn't respond anything, it is freezing. I have already installed CH341 driver on my laptop for rs485 to usb config device. It showing the correct com port when I checked in device manager. But, I can't select the serial port in the app. I m using windows 11. Help me with that. I m sure KC868-HA-V21 module is working normal. It is sending some data frame when I press k1 button in the serial monitor. RE: KC868-HA-V21 serial port selector drop box freezing - admin - 02-24-2025 i think maybe windows problem. can you run our software by administrator mode. close all firewall. or you can use another computer for a testing. RE: KC868-HA-V21 serial port selector drop box freezing - PeterOo - 02-24-2025 (Yesterday, 12:13 AM)admin Wrote: i think maybe windows problem. can you run our software by administrator mode. close all firewall. or you can use another computer for a testing. Alright, will do it. |
