KC868-A8 TCP - Transmitter - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: KC868-A8 TCP - Transmitter (/showthread.php?tid=7728) |
KC868-A8 TCP - Transmitter - Dm81 - 02-26-2025 Good Morning Is it possible send frequency through TCP to the KC868-A8 Transmitter? thank you RE: KC868-A8 TCP - Transmitter - admin - 02-26-2025 ??? RE: KC868-A8 TCP - Transmitter - Dm81 - 02-26-2025 (02-26-2025, 12:37 PM)admin Wrote: ???is there tcp command to send frequency through transmitter?? RE: KC868-A8 TCP - Transmitter - admin - 02-26-2025 what means "send frequency through transmitter" ?? RF module? if you want send RF signal, the frequency fixed with 433MHz, it according to hardware, not by software. RE: KC868-A8 TCP - Transmitter - Dm81 - 03-01-2025 (02-26-2025, 10:23 PM)admin Wrote: what means "send frequency through transmitter" ?? RF module? if you want send RF signal, the frequency fixed with 433MHz, it according to hardware, not by software.sorry , I mean, with firmware V2.xx is it possible to control RF module through TCP command and send frequency? I hope you understand now RE: KC868-A8 TCP - Transmitter - admin - 03-01-2025 yes, support send learned RF signal by TCP or MQTT. for example: 15. Send one RF signal have learned RELAY-RF-RUN-255,id Send: RELAY-RF-RUN-255,1 Feedback: RELAY-RF-RUN-255,1,OK here is protocol document: https://www.kincony.com/forum/attachment.php?aid=2873 |
