How to control light by switch using digital input in LAN? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: How to control light by switch using digital input in LAN? (/showthread.php?tid=78) Pages:
1
2
How to control light by switch using digital input in LAN? - acedera - 12-17-2020 So i wanna turn on anf off light using switch connected to digital input. If input 1 is on then relay1 is on and if off input1 then relay1 is off. How to programm it ? Not use cloud server only Lan RE: How to control light by switch using digital input in LAN? - admin - 12-18-2020 this need add switch terminal board. now the input port is use for sensor trigger scene. which controller model you have used ? RE: How to control light by switch using digital input in LAN? - acedera - 12-18-2020 Model H8. I order switch board but wanna use only digital input. RE: How to control light by switch using digital input in LAN? - admin - 12-18-2020 ok, KC868-H8 relay controller have another firmware for button control , here is video link: https://youtu.be/HlxVVIB2yXk https://youtu.be/QM8E4NF2NNE do you need as this ? If this is ok, you need a ST-link to download the firmware (we can send to you). here is ST-link link: https://www.aliexpress.com/item/33023499911.html?spm=2114.12010615.8148356.1.4dea6c0atNeYFY RE: How to control light by switch using digital input in LAN? - acedera - 12-18-2020 Can you send firmware to sorrel2@mail.ru RE: How to control light by switch using digital input in LAN? - admin - 12-18-2020 we will send you on Monday when we work time. RE: How to control light by switch using digital input in LAN? - acedera - 12-18-2020 https://www.kincony.com/kc868-h8h32-relay-local-control-sample-code-by-python.html Can you put a TXT example code of sample code by python Very bad quality of image file RE: How to control light by switch using digital input in LAN? - admin - 12-18-2020 https://github.com/hzkincony/8-Channel-Network-Relay-Controlled-By-Python RE: How to control light by switch using digital input in LAN? - acedera - 12-19-2020 Thanks!!! RE: How to control light by switch using digital input in LAN? - SpoX - 01-09-2021 Can I get a firmware for the KC868-H8 module that works as in the video link: https://youtu.be/HlxVVIB2yXk Does this firmware support the voice module? |
