What is the Minimal Power Consumption for A16 board - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: What is the Minimal Power Consumption for A16 board (/showthread.php?tid=7808) |
What is the Minimal Power Consumption for A16 board - vovo500 - 03-16-2025 Hi, I read that the A16 board requires 1,5A power supply. However, what is the minimal power consumption of the board? My requirements are implementable with the ESP32 in deep sleep mode most of the time. It would be good to implement high availability. So, for the ESP32, I could implement a USV with a small lithium battery. How about the periphery? How much power does it need? Is it possible to switch of the periphery (I/O pins, USB port, Network)via software? Thank you RE: What is the Minimal Power Consumption for A16 board - admin - 03-16-2025 i suggest you use multi meter to test. there are many different case. RE: What is the Minimal Power Consumption for A16 board - vovo500 - 03-16-2025 (03-16-2025, 11:39 AM)In admin Wrote: i suggest you use multi meter to test. there are many different case. I’ll report the results here. Thank you, Volkmar RE: What is the Minimal Power Consumption for A16 board - damian87ew - 03-21-2025 (03-16-2025, 08:17 AM)vovo500 Wrote: Hi,https://ibb.co/5h6fYk8S https://ibb.co/G4yL8X4b minimium 4.9V stabil 4.9V RE: What is the Minimal Power Consumption for A16 board - admin - 03-22-2025 thanks share your result. |
