Connecting to a-32pro - Printable Version
+--- Thread: Connecting to a-32pro (/showthread.php?tid=7852)
Connecting to a-32pro - drazvan2003 - 03-21-2025
I have the a-32pro that i configured and everything its working nice but every time i need to update the code i have use a type c usb cable and connect the pcb to my computer.
Is there a way to connect to it to update the code via ethernet cable or wifi ? if yes can you provide guidance pls ?
And is there a way to be able to dim the lights using this board ?
Best regards,
Razvan
RE: Connecting to a-32pro - admin - 03-22-2025
we will save your suggestion, maybe improve in future.
A32Pro have 2 channel DAC 0-10v ouput ports, can use for dimmer, just add dimmer DC12-24V driver or AC220v SSR driver.
if you want more channel, you can chose KC868-D16 or KC868-AP dimmer controller, that's 16 channel dimmer version.
RE: Connecting to a-32pro - drazvan2003 - 03-24-2025
(03-22-2025, 12:55 AM)admin Wrote: we will save your suggestion, maybe improve in future.
yes i have also theĀ  KC868-D16. i can use KC868-D16 to be able to dim the lights ?
RE: Connecting to a-32pro - admin - 03-24-2025
sure, use KC868-D16 + driver.
