Simulating RF Remote Button Press via Relay - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Simulating RF Remote Button Press via Relay (/showthread.php?tid=7891) |
Simulating RF Remote Button Press via Relay - sebagsm - 04-01-2025 Hi everyone, I'm using a KC868-A16, and I have an RF remote control that operates at 12V using a 12V battery. My goal is to use the KC868-A16 to simulate a button press on the RF remote, so I can trigger it from Home Assistant. I’ve opened the remote and soldered two wires to the button I want to control. I know that:
So instead, I want to use one of the mechanical relays on the KC868-A16 (e.g. Relay 1) to physically short the button pins, just like a real button press. My question is:
RE: Simulating RF Remote Button Press via Relay - admin - 04-01-2025 i suggest you chose relay board, NOT mosfet board. such as chose KC868-A16S relay controller. the relay output is dry contact, connect to your remote's button wire is better. RE: Simulating RF Remote Button Press via Relay - twostar - 04-02-2025 If the OP already has the A16 then it's much easier to get an external relay board than replacing the A16 with an A16S. You can get the relay boards from Aliexpress for a few dollars, just make sure that they're high-triggered not low-triggered since most of them are low-triggered for Arduino use (the linked ones are high-triggered). So what you're doing is converting the wet-contact output to a dry-contact one. |
