friendly_name: TA
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
external_components:
- source:
type: git
ref: v1.1.0
#logger:
# level: DEBUG
# hardware_uart: USB_SERIAL_JTAG
encryption:
# ethernet:
# type: W5500
# clk_pin: GPIO1
# mosi_pin: GPIO2
# miso_pin: GPIO41
# cs_pin: GPIO42
# interrupt_pin: GPIO43
# reset_pin: GPIO44
wifi:
ssid: KinCony
password: 'a12345678'
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
pcf8574:
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
address: 0x22
pcf8575: true
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 39
rx_pin: 38
- id: tuya_mcu_uart
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 9600
tuya_wifi_mcu:
# tuya mcu product id
product_id: asowcylz7am5cbtp
uart_id: tuya_mcu_uart
wifi_reset_pin: 28
wifi_led_pin: 16
- platform: uart
uart_id: uart_1
pcf8574: pcf8574_hub_out_1
number: 14
mode: OUTPUT
- platform: tuya_wifi_mcu
dp_id: 1
# hide from homeassistant ui
internal: true
bind_switch_id: "ta_output01"
number: 15
mode: OUTPUT
dp_id: 2
internal: true
bind_switch_id: "ta_output02"
mode: INPUT
dp_id: 111
bind_binary_sensor_id: ta_input01
internal: true
number: 1
mode: INPUT
dp_id: 112
bind_binary_sensor_id: ta_input02
internal: true
number: 2
mode: INPUT
dp_id: 113
bind_binary_sensor_id: ta_input03
internal: true
number: 3
mode: INPUT
dp_id: 114
bind_binary_sensor_id: ta_input04
internal: true
number: 4
mode: INPUT
dp_id: 115
bind_binary_sensor_id: ta_input05
internal: true
number: 5
mode: INPUT
dp_id: 116
bind_binary_sensor_id: ta_input06
internal: true
number: 6
mode: INPUT
dp_id: 117
bind_binary_sensor_id: ta_input07
internal: true
number: 7
mode: INPUT
dp_id: 118
bind_binary_sensor_id: ta_input08
internal: true
number: 8
mode: INPUT
dp_id: 119
bind_binary_sensor_id: ta_input09
internal: true
number: 9
mode: INPUT
dp_id: 120
bind_binary_sensor_id: ta_input10
internal: true
number: 10
mode: INPUT
dp_id: 121
bind_binary_sensor_id: ta_input11
internal: true
number: 11
mode: INPUT
dp_id: 122
bind_binary_sensor_id: ta_input12
internal: true
##pull-up resistance on PCB
number: 9
number: 11
number: 5
number: 4
number: 7
inverted: false
number: 6
inverted: false
number: 13
inverted: false
number: 40
inverted: false
number: 14
inverted: false
number: 48
inverted: false
number: 21
inverted: false
number: 47
inverted: false
inverted: false
number: 12
inverted: false
web_server:
port: 80
