How to use channel 5,6,7,8 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AG / AG Pro / AG8 / Z1 (https://www.kincony.com/forum/forumdisplay.php?fid=30) +--- Thread: How to use channel 5,6,7,8 (/showthread.php?tid=8009) |
How to use channel 5,6,7,8 - tenabiker - 04-23-2025 If only 4 channel can be used by ESP Home, is there any way to use channel 5,6,7,8 of AG8 module ? RE: How to use channel 5,6,7,8 - admin - 04-23-2025 download KCS v3 for AG8 controller is ok. RE: How to use channel 5,6,7,8 - tenabiker - 04-24-2025 (04-23-2025, 11:05 PM)admin Wrote: download KCS v3 for AG8 controller is ok. I tried that first,, using KCS interface I could try channels 1-4 (didnt tried others). Unfortunatelly I couldnt make homeassistant work with it. Is there any tutorial for that ? Is there any way to use climate platform with KCS firmware just by indicating AC brand and model for example? THanks RE: How to use channel 5,6,7,8 - admin - 04-24-2025 if use KCS v3 firmware for AG8, all 8 channel IR sender can by used. here is video tour: https://youtu.be/Lw0Mn_QbV9A RE: How to use channel 5,6,7,8 - tenabiker - 04-25-2025 (04-24-2025, 11:56 PM)admin Wrote: if use KCS v3 firmware for AG8, all 8 channel IR sender can by used. here is video tour: https://youtu.be/Lw0Mn_QbV9A Hi , thanks for reply. But in this case we do need to leard code by code. Is there any way to use climate platform and only point to ir channel at AG8 ? One more thing, I could not make it work with homeassistant. It is auto discovering, but did not add to device lists. Using 3.9.1 kcs and latest HA update. RE: How to use channel 5,6,7,8 - admin - 04-25-2025 1. if you want use ESPHome, ESPHome only support 4 channel IR sender for ESP32-S3 chip. Maybe in future, they will update for ESPHome. 2. you can integraet by mqtt for every IR signal manually. |
