Communication between two A16 over RS485 on ESPHOME with uart not working - Printable Version
+--- Thread: Communication between two A16 over RS485 on ESPHOME with uart not working (/showthread.php?tid=8169)
Communication between two A16 over RS485 on ESPHOME with uart not working - MarioR - 06-09-2025
i would like to have two A16s communicate with uart via the RS485 in the ESPHome.
The two RS485 are cross-connected A=>B and B=>A.
One A16 is the transmitter and the other is the receiver.
When the binary sensor is triggered, a message should be sent to the receiver, which should then trigger an action.
So far the log says that the transmitter is transmitting, but according to the log nothing arrives at the receiver.
Transmitter, i have shortened the yaml to the essential parts:
substitutions:
  mydelay_on: 50ms
  mydelay_off: 300ms
  uartcommand_allup: 0xAC, 0xAB, 0x01, 0x99
  uartcommand_alldown: 0xAC, 0xAB, 0x02, 0x99
  friendly_name: Roller_Shutter_2
  on_boot:
    priority: -100
    then:
      - lambda: |-
          id(rollershutter_2).MySetup();
          id(rollershutter_2).InitialRun();
esp32:
  board: esp32dev
  framework:
    type: esp-idf
debug:
# Logger must be at least debug (default)
  level: DEBUG
  baud_rate: 9600
uart:
  - id: rs485
    tx_pin: GPIO13
    rx_pin: GPIO16
    baud_rate: 9600
    stop_bits: 1
    parity: NONE
    data_bits: 8
    debug:
      direction: BOTH
      dummy_receiver: false
      sequence:
        - lambda: |-
            UARTDebug::log_binary(direction, bytes, ';');
button:
  - platform: uart
    uart_id: rs485
    data: $uartcommand_allup
  - platform: uart
    uart_id: rs485
    data: $uartcommand_alldown
pcf8574:
  - id: inputs_1_8
    address: 0x22
    pcf8575: false
  - id: inputs_9_16
    address: 0x21
    pcf8575: false
  - id: outputs_1_8
    address: 0x24
    pcf8575: false
  - id: outputs_9_16
    address: 0x25
    pcf8575: false
      pcf8574: inputs_9_16
      number: 2
      mode: INPUT
    filters:
      - delayed_on: $mydelay_on
      - delayed_off: $mydelay_off
    on_press:
      then:
        - uart.write: [0xAC, 0xAB, 0x01, 0x99]
      number: 3
      mode: INPUT
    filters:
    on_press:
      then:
        - uart.write: [0xAC, 0xAB, 0x02, 0x99]
      number: 4
      mode: INPUT
    filters:
    on_press:
      then:
        - switch.turn_on: uart_master_holiday
    on_release:
      then:
        - switch.turn_off: uart_master_holiday
  - platform: template
    optimistic: True
    on_turn_on:
      then:
        - uart.write: [0xAC, 0xAB, 0x03, 0x99]
    on_turn_off:
      then:
        - uart.write: [0xAC, 0xAB, 0x04, 0x99]
Receiver, also  shortened:
  friendly_name: Roller_Shutter_1
esp32:
  board: esp32dev
  framework:
    type: esp-idf
debug:
  level: DEBUG
  baud_rate: 9600
uart:
  - id: rs485
    tx_pin: GPIO13
    rx_pin: GPIO16
    baud_rate: 9600
    stop_bits: 1
    parity: NONE
    data_bits: 8
    debug:
      direction: RX
      dummy_receiver: true
      sequence:
        - lambda: |-
Where can i search the problem?
Best regards Mario
RE: Communication between two A16 over RS485 on ESPHOME with uart not working - admin - 06-09-2025
i suggest you download by KCS firmware, it will be easy.
send customize RS485 command by IFTTT.
RE: Communication between two A16 over RS485 on ESPHOME with uart not working - MarioR - 06-10-2025
Sending communication via IFTTT is not an alternative to native RS485 communication.
IFTTT requires a functioning network.
RS485 works without a network and is therefore much more fail-safe, similar to a PLC control system.
My shutter control via ESPHome can be controlled via Homeassistant, but also works completely independently.
Best regards
Mario
RE: Communication between two A16 over RS485 on ESPHOME with uart not working - admin - 06-10-2025
no, my means, you download KCS v2 firmware to KC868-A16, set by IFTTT, it's local IFTTT, work without network, just send command by RS485 port.
here is KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
RE: Communication between two A16 over RS485 on ESPHOME with uart not working - MarioR - 06-11-2025
The problem was that I ignored the RS485 interface type. With the RS485, A=>A and B=>B are connected, as opposed to a ‘normal’ UART connection.
I will not use their firmware.
I asked here because this forum is advertised as a support forum. Apparently, however, it is just an advertising and sales forum.
RE: Communication between two A16 over RS485 on ESPHOME with uart not working - admin - 06-12-2025
here is RS485 modbus protocol: https://www.kincony.com/forum/showthread.php?tid=2528
here is KC868-A16 esp32 pin define: https://www.kincony.com/forum/showthread.php?tid=1666
how to modify by ESPHome yaml, your question post to esphome community is more suitable.
