Lesson21- KC868-A8 ethernet work with home assistant by ESP home - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: Lesson21- KC868-A8 ethernet work with home assistant by ESP home (/showthread.php?tid=824) |
Lesson21- KC868-A8 ethernet work with home assistant by ESP home - admin - 10-05-2021 here is ESP home config file work with KC868-A8 by ethernet static IP: esphome: name: relay1 platform: ESP32 board: esp32dev # Example configuration entry for ESP32 i2c: sda: 4 scl: 5 scan: true id: bus_a # Example configuration entry ethernet: type: LAN8720 mdc_pin: GPIO23 mdio_pin: GPIO18 clk_mode: GPIO17_OUT phy_addr: 0 # Optional manual IP manual_ip: static_ip: 192.168.2.199 gateway: 192.168.2.1 subnet: 255.255.255.0 # Example configuration entry pcf8574: - id: 'pcf8574_hub' address: 0x24 # Individual outputs switch: - platform: gpio name: "light1" pin: pcf8574: pcf8574_hub # Use pin number 0 number: 0 # One of INPUT or OUTPUT mode: OUTPUT inverted: false # Enable logging logger: # Enable Home Assistant API api: |
