Need Help: SIM7600E Doesn’t Answer Call for Relay Command - Printable Version
+--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4)
+--- Thread: Need Help: SIM7600E Doesn’t Answer Call for Relay Command (/showthread.php?tid=8318)
Need Help: SIM7600E Doesn’t Answer Call for Relay Command - hamshini_marat - 07-14-2025
Hello Admin,
I’m using the ESP32-S3 2-channel relay module – KC868-A2v3 with the GSM SIM7600E, and I tried the IFTTT method to control the relay. However, when I call the number of the SIM card inserted in the GSM module, it doesn’t answer automatically so that I can type in the code with # to turn the relay on or off. Instead, the call hangs up after a few rings.
I’ve attached screenshots of my configuration using the web browser.
Could you please guide me on what I might be missing or doing wrong?
Looking forward to your reply.
Thanks in advance.
With regards,
Hamshini
RE: Need Help: SIM7600E Doesn’t Answer Call for Relay Command - admin - 07-14-2025
enter "edit" button, take photo of your setting screen.
RE: Need Help: SIM7600E Doesn’t Answer Call for Relay Command - hamshini_marat - 07-15-2025
(07-14-2025, 10:27 AM)admin Wrote: enter "edit" button, take photo of your setting screen.
I've attached screenshots of all the IFTTT settings as requested.
RE: Need Help: SIM7600E Doesn’t Answer Call for Relay Command - admin - 07-16-2025
what KCS firmware version you are using? take a photo.
can you take a video of your problem, send to whatsapp number: +86-15381188302 so that can understand you.
