extension keyboard: Hold functionality - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: extension keyboard: Hold functionality (/showthread.php?tid=841) |
extension keyboard: Hold functionality - democles9308 - 10-10-2021 Hi, Was wondering if the firmware of the 32 buttons extension keyboard might be modified so the press & hold function could also be used. For the moment it's only possible on the Mobile app. I made one button with press& hold function using and ESP8266 and it works but hoped the µprocessor on the board could be reprogrammed.. Many thanks Democles RE: extension keyboard: Hold functionality - admin - 10-11-2021 which relay controller you are using? Do you want to use 32 button extension keyboard with KinCony's relay controller or your own relay board? RE: extension keyboard: Hold functionality - democles9308 - 11-05-2021 (10-11-2021, 12:07 AM)admin Wrote: which relay controller you are using? Do you want to use 32 button extension keyboard with KinCony's relay controller or your own relay board? Would like to use the 32b extension keyboard with the KinCony controller (and with press &hold if possible). Thanks! RE: extension keyboard: Hold functionality - admin - 11-05-2021 now the H32BS already support click and double click mode. so one button can use for two mode. |
