KC868-AP Control System (MQTT + Home Assistant) - Printable Version
+--- Thread: KC868-AP Control System (MQTT + Home Assistant) (/showthread.php?tid=8575)
KC868-AP Control System (MQTT + Home Assistant) - nikhuge - 09-22-2025
A robust MicroPython application for ESP32 controlling the KC868-AP dimmer/relay hardware with native Home Assistant MQTT discovery.
https://github.com/charithmadhuranga/Kincony-AP-Homeassistant-Micropython-Mqtt
RE: KC868-AP Control System (MQTT + Home Assistant) - IslaKate - 10-20-2025
That’s a solid project! Using MicroPython on the ESP32 with native Home Assistant MQTT discovery makes integration smooth and efficient. Great way to control the KC868-AP dimmer and relay hardware seamlessly.
RE: KC868-AP Control System (MQTT + Home Assistant) - Zita15as - 11-27-2025
Looks like a clean setup. I’m curious whether you’ve tested how it handles reconnections when WiFi drops, since ESP32 projects often run into that.
