Node-Red flows download for KC868 Smart Controller - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Node-Red flows download for KC868 Smart Controller (/showthread.php?tid=87) |
Node-Red flows download for KC868 Smart Controller - admin - 12-21-2020 Here are some Node-Red flows download link for KC868-Hx relay controller and KC868-COL logical controller in our YouTube video tours. https://www.kincony.com/download/Node-Red-flows.zip KC868-COL-logical-controller.json KC868-COL for Node_Red, to read all digital input , analog input,temperature sensor input data. KC868-D8-homekit-dimmer.json KC868-D8 for Node-Red, control dimmer lamp in Apple Homekit KC868-Hx-relay-controller-home-kit-lamp.json KC868-Hx relay controller Turn ON/OFF one lamp in Apple Homekit KC868-Hx-relay-controller-home-kit-32lamps.json KC868-H32 relay controller Turn ON/OFF 32 channel lamp in Apple Homekit KC868-Hx-relay-controller-switch-panel-feedback.json Wall switch panel control lamp synchronous relay state for Node-Red RE: Node-Red flows download for KC868 Smart Controller - Adrian - 05-16-2021 Could you put similar flows but for MQTT control? RE: Node-Red flows download for KC868 Smart Controller - admin - 05-16-2021 you can use MQTT node, that's very easy, just set the topic and payload. when we have free time, we can make a sample flows. |
