A32pro MQTT auto discovery HA - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: A32pro MQTT auto discovery HA (/showthread.php?tid=8746) |
A32pro MQTT auto discovery HA - Nikola - 11-17-2025 “Why is it that every time I shut down Home Assistant and start it again, the A32pro MQTT auto-discovery for Home Assistant doesn’t work until I go to the A32pro’s IP address and reset the MQTT settings?” Why is it that every time I shut down Home Assistant and start it again, the A32pro MQTT auto-discovery for Home Assistant doesn’t work until I go to the A32pro’s IP address and reset the MQTT settings? RE: A32pro MQTT auto discovery HA - admin - 11-17-2025 because need home assistant start up firstly. then A32Pro power on, will auto discovery by home assistant. |
