Low Level Relay Trigger - Printable Version
+--- Forum: KC868-A16v3 (https://www.kincony.com/forum/forumdisplay.php?fid=68)
+--- Thread: Low Level Relay Trigger (/showthread.php?tid=8810)
Low Level Relay Trigger - shawn@itcharleston.com - 12-11-2025
Can the KC868-A16v3 be configured to output a Low Level (Ground) to trigger relays on the SainSmart 16-Channel 12V Relay Module Board?
RE: Low Level Relay Trigger - admin - 12-11-2025
repied on another thread.
RE: Low Level Relay Trigger - shawn@itcharleston.com - 12-11-2025
The relays I have require a ground input to activate. I was wondering if there was a way to have the KC868-A16v3 give a ground output instead of positive.
I know I could purchase a high level relay board. I was just trying to use what I have.
Thanks
why not buy a relay board version that use by positive?
the level convert module use for convert digital input signal.
I'm guessing the answer is no, that it cannot be configured to send a low-level signal from the Outputs.
I was trying to use a relay board I have. I just ordered an 8-channel relay board that can take high or low-level input
RE: Low Level Relay Trigger - admin - 12-12-2025
it can't outout low level signal.
