KC868-H16B Mqtt stops working intermittently - Printable Version
+--- Thread: KC868-H16B Mqtt stops working intermittently (/showthread.php?tid=8823)
KC868-H16B Mqtt stops working intermittently - hlavaste - 12-16-2025
Hi,
I have KC868-H16B relay.
What seems to happen is that Mqtt client stops listening to subscriptions after a while.
I have ports 1-6 for lights, and port 16 for heating.
Randomly, port 16 stops responding to mqtt state changes.
Looking at the explorer, the set value is changed to 1 but state is not changed accordingly. This only affects port 16. ports 1-6 are still working.
If I power cycle the relay, it's back to normal again.
Version I'm running is H16B_V4.35.
Any ideas?
Thanks,
Heikki
RE: KC868-H16B Mqtt stops working intermittently - admin - 12-17-2025
what power supply you are using?
